A nother problem No Dimensions or measurement not showing
Not applicable
Nother problem just started, I have no Dimensions or measurements not showing making
Circles no measurements
have to do it manually and squares too, and makind distance measurements from
a square's center doesn't work to
All of these problems occured when upgraded to new Version and removed older one
I installed the software there was a point in install Do you want overwrite some
files, that was left from older Version that wan't removed
I have not had any problem with Version 20
Dan
Re: A nother problem No Dimensions or measurement not showing
Not applicable
Dan,
I'm going to try to comprehend all of this.
> showing making
> from
Is the problem that at one time dimensions were being placed as geometry was
created? If that is the case, then make sure that the Auto-Dimension button
is down. It is under the Dimension command group. Also make sure that
Maintain Relationships is on. It is under the Tools tab and in the
Assistants command group. you may also want to enable the display of
relationship Handles under the View tab and in the Show command group.
> overwrite some
This is expected. During installation some files needed for installation
will be put into a temporary location. It is simple requesting that the new
installation overwrite the temporary files. Always answer yes to overwrite
the files.
Rick B.
Not applicable
Auto-Dimension button and Maintain Relationships is on
I click on the icon it shows it been actived I go my to drawing It is not actived
HP Pavilion A800n
2.2 Ghtz
1.43Gbits of Ram
Dan
"Ricky Black" wrote:
>Dan,
>> showing making
>> from
>> overwrite some
>the files.
>Regards,
>Rick B.
Not applicable
I tried the measurements again it doesn't
click on the icon shows that it is actived then nothing
reload the software too.
Dan from Mt. Prospect,il
>Dan,
>> showing making
>> from
>> overwrite some
>the files.
>Regards,
>Rick B.
Not applicable
Dan,
I will try to help you reset the UI back to the original settings.
Uninstalling and reinstalling will not undo anything you may have changed.
After you do the following enable Maintain relationships again. Enable
relationship Handles again.
How much do you know about the registry? Be very careful anytime you are
modifying the registry. A mistake can be can make your entire system fail!!!
Read all the directions before you begin. Pay close attention to the
registry entries specified.
1. Close Solid Edge 2D Drafting.
2. Click on Start.
3. Click on Run.
4. Key-in 'regedit' in the 'Open:' command line field . Just key in the word
regedit without the tick marks.
5. Click OK.
This open the Registry Editor. Be very careful making the following change.
Follow the directions exactly.
6. Click on the + in front of HKEY_CURRENT_USER. This will expand this
entry.
7. Under HKEY_CURRENT_USER click on the + in front of 'Software'. This will
expand this entry.
8. Under 'Software', click on the + in front of 'Unigraphics Solutions'.
This will expand this entry.
9. Under 'Unigraphics Solutions' click on 'Solid Edge'. Do not click on the
+ in front of 'Solid Edge'. Solid Edge should now be highlighted.
10. Verify where you are: HKEY_CURRENT_USER - Software - Unigraphics
Solutions - Solid Edge. The only thing highlighted should be Solid Edge.
11. Press the Delete key on the keyboard.
12. Click on Yes to confirm delete key. The Solid Edge entry will be
removed. The software will add it back as you customize the UI again.
13. Click the 'X' in the upper right corner of the registry editor to close
it.
14. Start Solid Edge 2D Drafting again and enable the relationships toolbar.
You should be good to go.
Rick B.
Not applicable
not working
the circles are not showing the measures just showing center of the circle
and squres have nothing being
>Dan,
>2. Click on Start.
>3. Click on Run.
>5. Click OK.
>entry.
>expand this entry.
>it.
>Regards,
>Rick B.
Not applicable
Dan,
I see nothing out of the ordinary in the file you posted. Can you
explain what issue it is your having? The explanation in your post didn't
really state any issue.
http://grundey.blogspot.com
"Dan Donna" wrote in message
news:493a892a@bbsnotes.ugs.com...
> not working
>>Dan,
>>fail!!!
>>2. Click on Start.
>>3. Click on Run.
>>word
>>5. Click OK.
>>change.
>>entry.
>>will
>>expand this entry.
>>the
>>close
>>it.
>>toolbar.
>>Regards,
>>Rick B.
Not applicable
I reset IU to original settingsthrough regedit and auto measurements of circles are
not showing and same for squares squares
Sill not working
Dan
"PellaKen" wrote:
>Dan,
>Ken
>> not working
>>>Dan,
>>>fail!!!
>>>2. Click on Start.
>>>3. Click on Run.
>>>word
>>>5. Click OK.
>>>change.
>>>entry.
>>>will
>>>expand this entry.
>>>the
>>>close
>>>it.
>>>toolbar.
>>>Regards,
>>>Rick B.
Not applicable
Dan,
Check your Intellisketch settings as shown in the attached image.
David
news:493bc5b2$1@bbsnotes.ugs.com...
> circles are
> Sill not working
> Dan
> "PellaKen" wrote:
>>Dan,
>>Ken
>>> not working
>>> circle
>>>>Dan,
>>>>changed.
>>>>fail!!!
>>>>2. Click on Start.
>>>>3. Click on Run.
>>>>word
>>>>5. Click OK.
>>>>change.
>>>>entry.
>>>>will
>>>>expand this entry.
>>>>the
>>>>close
>>>>it.
>>>>toolbar.
>>>>Regards,
>>>>Rick B.
Not applicable
Fix that Problem, still one more problem
(I did not have this problem with version 20)
when I change distance between value the smaller square moves out side larger
square
Dan
"David L Rieschick" wrote:
>Dan,
>David
>> circles are
>> Sill not working
>> Dan
>> "PellaKen" wrote:
>>>Dan,
>>>Ken
>>>> not working
>>>> circle
>>>>>Dan,
>>>>>changed.
>>>>>fail!!!
>>>>>2. Click on Start.
>>>>>3. Click on Run.
>>>>>word
>>>>>5. Click OK.
>>>>>change.
>>>>>entry.
>>>>>will
>>>>>expand this entry.
>>>>>the
>>>>>close
>>>>>it.
>>>>>toolbar.
>>>>>Regards,
>>>>>Rick B.
