AMD Ryzen
Anyone any experience with AMD ryzen (1700x or 1800x?) How does it perform with Solid Edge?
Can I buy it or can I better chose the Intel 7700k?
With friendly regards,
Mathias Boysen
Re: AMD Ryzen
I went with the AMD 1700X, saved $100 over the 1800X and didn't lose many Hz.
System has been stable and cool.  I'm also using the AMD Firepro W7100 with it.
Had I the proper case (I used an old one I had on the shelf), I would have used liquid cooling.
____________________________________
--Scott Wertel, P.E.
Re: AMD Ryzen
ok, thank you for the reply.
How is Solid Edge is behaving on AMD? I've read somewere that the program is optimised for Intel so...?
