[ASM] Suppress assembly mate by condition
I'm designing a machine where a component follow a path, driven by a variable named "A". It happens that in a point of the path, I need to suppress a mate of the component and activate another one, to make it follows the right path with the right timing.
something like:
IF "A"<10 THEN MATE_1=ON
IF "A"<10 THEN MATE_2=OFF
Is this possible?
____________________________
http://www.stimarchetti.it
Design of automation
3 REPLIES 3
Betreff: [ASM] Suppress assembly mate by condition
HI @Alessandro
not absolutely confident, but could it be, that I have seen this in the ST10 - What's New?
Wolfgang
Yes Wolfgang, you are correct. This has been added in ST10:
Greg
Hi @GregLuckett
thank You for confirming my assumption
Wolfgang
