Aborted Install
Not applicable
Uninstalled V102 to update to V103.
Ran update from your site and also downloaded and ran from desktop with same result.
Program aborts with "The wizard was interupted..........." (see attached)
UAC turned off both times.
Rick
Re: Aborted Install
Not applicable
Rick,
Had you upgraded from V100 to V102?
There was an issue where installing V102 would not check for a previous
version.
If this is the case, there may still be old version information still around
that is aborting the install.
Rick B.
"rickbrown47@msn.com"
wrote in message
news:rickbrown47msn.com.4xa820@noreply.bbs.industrysoftware.automation.siemens.com...
> same result.
> attached)
> Rick
> |Filename: abort.jpg |
> |Download:
> http://bbs.industrysoftware.automation.siemens.com/vbulletin/attachment.php?attachmentid=4100|
> rickbrown47@msn.com
> rickbrown47@msn.com's Profile:
> http://bbs.industrysoftware.automation.siemens.com/vbulletin/member.php?userid=145400
> View this thread:
> http://bbs.industrysoftware.automation.siemens.com/vbulletin/showthread.php?t=45976
