About solid edge st6 student version.
the solid edge st6 is not installing but the icon is present on the home screen . what is the problem?
Re: About solid edge st6 student version.
What OS are you trying to install it on?
http://Grundey.blogspot.com
i am using windows 7 ultimate , 32 bit OS , but still the download failed.
When you install, do you right click on "setup.exe" and select "Run as Administrator"?
