Academic code for ST8
I had recieved an academic code for ST7 but could not run it in Windows 10. So I downloaded ST8 but the academic code does not work. Is there any way I can get a new code?
Re: Academic code for ST8
Hi there,
If you go through the sign up process again, you will recieve the new ST8 code via the email address given at sign up.
Solid Edge 2019 [MP1] Classic [x3 seats]
I have signed up again to get ST8 this morning but still don't have any mail.
How long should I wait before trying again ?
TIA.
@ABM wrote:
Hi there,
In all of the cases I've helped student users get sorted with Solid Edge, they receive their email either immediately, or within minutes, after completing the sign up. Just set my daughters low spec HP laptop [also just upgraded it to Windows 10] with ST8, and that went smoothly.
I would try again if nothing happens after 1 hour, but just double check the email address is correctly entered......good luck.
Thanks for your answer.
It turns out than giving my usual mail doesn't work (of course I have checked it : there is no mistake) but an alternate does work.
Have a nice day.
