Access Code and 32 Bit Version
N/A
I cant get passed the access code part, and also got the 32 bit version. I need some help on installing the product alone, then can address the 32 bit part. Thanks for any help.
Re: Access Code and 32 Bit Version
N/A
Not sure what you mean when referring to "access code". The 32 bit
version will run just fine on 64 bit OS and I do not believe you have an
option when downloading the Student Edition.
http://grundey.blogspot.com
32 Bit is the only Student Edition version available. Use the URL to download the executable to a local folder and run it. Use the instructions in the email for applying the attached license file.
