Re: Access Custom Properties using a Draft Selected View (VBA)
@xRobin wrote:
Yes Bruce,
It has to be in the title block, I suggested the part list table but the document has to be delivered to a customer and they didn't like the idea.
I guess it shows that the customer isn't always right. Or necessarily sane.
Bruce Shand
12Gage
Not sure if this is a good way to work or not, as provider I deliver what the customer needs, at this moment Im doing this work manually, I understand there are some programmers here thats why Im posting my problem, Im going to keep searching for a solution, as soon as I find something usesfull I'll be glad to share wit you guys.
thanks
@xRobinYou probably already considered this but what if you take the title block section off of your background sheet, then make a parts list that resembles a title block and insert it at the former location of the title block on each sheet referencing a view on that sheet? The "title block" probably won't look exactly like the original one but why should the customer care as long as the info is there?
Bruce Shand
