Activate reference points
Hello ST8 community
I am trying to cut a solid with a sketch. I am using a finite cut command. I want to chose the edge of the solid as a reference point for the finite distance. But somehow its not recognizing any refernce points , for eg. edges or sides. Is there any way to enable/disable refence points? (P.S. all the refence points are activated in sketching menu.)Screenshot (5).png
Re: Activate reference points
You have them turned off - see the red X on the right hand end of the extrude toolbar. Click that and select what you want.
Ahh! I am so stupid. Haha, thanks!
