Active inactive dimension..
Hi~
edge users..
Active And Inactive questions in assembly environment
Opened in an inactive state.
I think the ideal is the fastest.
You only need to activate the part to make dimension measurements.
Is there a way to measure dimensions in the inactive state?
Re: Active inactive dimension..
your understanding is correct.
no,  geometry must be active to "use"
Matt Johnson
Teamcenter 10.1.7
