Add JIS material database
Hi everyone,
Please advise on Adding jis material database on material table.
The shortcut way is save or update the existing database. My question is. Does Siemens provide downloadable jis material database to be loaded into solid edge material table?
Thank you
Destian
Re: Add JIS material database
I think Siemens doesn't provide JIS db to material table. This link can be useful for you: link
BR,
Imics
