Add text note to dimension
Builder
Builder
How do I add a text note to a dimension ? I have the standard dimension and am trying to add a note after the dimension i.e. 200mm (text note).
Anthony
SE ST8
Betreff: Add text note to dimension
RMB on dimension and dimension prefix will give YOu the option to add prefix, suffix super or subfix
Wolfgang
Builder
Builder
Perfect, thank you Smiley Happy
