Addin with wizard
Hi.
I want to create a plugin with the wizard ISO Part. The wizard must be available to create from start menu ("File-New-My ISO Part") . Wizard configures parameters ISO part. Is an example from Altium and Visual Studio to describe the logic that I want to implement in the plugin
Q: how to implement my idea correctly?
Alitum Designer
Visual Studio
Re: Addin with wizard
Hi kavit, Welcome to the forum.
You will have a better target audience and luck posting this in the Solid Edge Developer Forum.
~Tushar Suradkar
www.SurfAndCode.in
Oops. My mistake. Message created in another thread. (click). This message can be deleted. Thanks
