Adding Save as Flat to quick Access
Just upgraded to ST9 (regret it already). Thanks for adding more mouse clicks to a now rubbish interface!
How do I add "Save as Flat" to my quick access bar so I don't have to waste 3 additional mouse clicks?
Thanks G
Re: Adding Save as Flat to quick Access
While in the sheet metal environment go to the Customize drop down and click Customize. Make sure you're on the Quick Access tab and change the Choose command from drop down to System Menu. Then select Save As Flat and hit Add.
Thank you.
