Adding Text Over Top Another Text
While I am editing a part with replace a copy to edit. For my attempt is to add another text over top the previous text with a suppress command. I noticed on the pathfinder... the previous name was changed. Is it possible to save both names for the assembly while creating a switch on switch off command to show different text pins.
http://screencast.com/t/Jr8fl6xxAN
Thank You
Greg
Re: Adding Text Over Top Another Text
@PO_LC wrote:
.... assembly while creating a switch on switch off command to show different text pins.
Greg,
Yes you can do this.....what you're looking for is called an assembly "Display Configurations"....look for this under the help [F1] menu, for details on how to go about it.
Solid Edge 2019 [MP8] Classic [x3 Seats - Cloud Enabled]
