Adding custom part in standard part (piping library).
Hello all,
I want to know the procedure for adding the custom part (piping fitting) into standard part library. I tried adding some pipe fitting and flanges into standard part but when i try to use those part inside Xpress route these custom parts are not visible to select from standard part. can someone help me in this with solution.?
5 REPLIES 5
Re: Adding custom part in standard part (piping library).
Did you run the macro for piping parts?
Yes i did run the macro for piping parts but still it isnt visible while trying to use that in xpress route. Can i get step by step procedure so that i will try once again following the procedure.
Siemens Creator
I also meet this problem, waiting the answer
Siemens Creator
I had solved thiss problem, thanks
So what is the solution???
Shane Murray
SE2019 MP6
