Adding file path below drawing format
Is there anyway to add a file path...c:/drawings/large assembly/parts...off drawing format, that can be turned on and off during print?
Re: Adding file path below drawing format
1-Legend
2-Text properties
3-Filename
Yasser
Betreff: Adding file path below drawing format
Hi @hoosier
what do You mean with "tunr on and off during printing"?
What exactly should be reached with that?
Wolfgang
You can use Yasser's suggestion and place the path on a layer that can be turned off during printing.
That was a no-brainer when you mentioned on/off, so are you looking for something automatic ?
