Adding hardware to tubing
PLM World Member Builder PLM World Member Builder
With this image what is needed to add hardware plus welding to tubing?
http://screencast.com/t/Wldt9e3X
Thank You
You would need to add that part to a new Assembly (ASM) d...
You would need to add that part to a new Assembly (ASM) document and then add your modeled hardware.  To be able to add weld beads you will need switch your Assembly mode to Weldment.
http://Grundey.blogspot.com
