Adding new layers to existing drawings
Hi Guys
if i have a .dft file with multiple drawing sheets and each sheet has a few different drawing views,
then I add a new layer to the model, this new layer appears on every view on every sheet and i have to manually go through and hide the layer everywhere, big drag!
If I use the "hide everywhere" option I do not have the option to turn the layer on in the sheet and views I want as it does not appear in the drawing view layer list. And I cannot turn the layer on in the model without it appearing everywhere.
Normally I leave all layers in the model turned on and hide the layers I don't want in each view.
Is there a better way to either manage my layers or hide them everywhere and turn back on selectively?
