Adjustable part problem?
We are attempting to use an adjustable part (rod stroke in an air cylinder) in an assembly and it seems like it's allowing mates in other parts, related or not, to be overridden with new values if not broken altogether.
Are there any known problems with ST8 MP1?
Edit: Let me rephrase that: Are there any problems related to adjustable parts?
Bruce Shand
Re: Adjustable part problem?
In retrospect it was probably caused by too many shaky parts. Once the assembly was gone back through with a finer tooth comb it worked ok.
Bruce Shand
