Affichage filetages
Bonjour,
Je souhaite afficher les filetages après avoir utilisé la fonction taraudage lors de la création d'une pièce 3D.
Merci pour votre aide
Re: Affichage filetages
Hi there,
You need to have your view set to display textures [I would've expected this to be ON by default], as threads are graphical only, not physical geometry. [you'd need to model helical cut, or protrusion, of the thread form to model them]
On View tab, on the style pallet.....seslect View Overrides, and check the box for Textures.....
