After install SE 2d can't find license
Not applicable
I've downloaded and installed the current SE-2d ST. I've downloaded the "current"
license file and put it in the SE/Programs folder as instructed. When I launch SE-2d
it cannot find the license file. What possible could be the problem? I've uninstalled
& cleared the registry at least 5 times, still no luck. I've tried calling for help,
but of course nobody answers the phone or I get transfered all over and back...
Does anyone know how to get around this problem?
Thanks! Jamie
Re: After install SE 2d can't find license
Not applicable
Jamie,
I guess you are installing Solid Edge 2D Drafting ST which is V100. You do
not have to worry with the license. All you should have to do is to simply
install the software. The license is installed for you during the
installation of the software. We did this to simplify the installation
process.
As for support on 2D Drafting, this newsgroup is your front line for
support.
Rick B.
Not applicable
Ricky,
I followed the directions. I gives me an error that it needs a valid license. I
am uploading a file of the error. Simply, it doesn't work.
Thank you for your help,
Jamie
"Ricky Black" wrote:
>Jamie,
>process.
>support.
>Regards,
>Rick B.
Not applicable
Jaime,
I sent an email directly to you with the license.
Rick B.
