All surface on solid edge ST9 Disappears
Anybody can help me to solve this problem :
- All surface on Solid edge ST9 (SE351) disappeared when drawing in Order environment. I closed the files and the Software and reopened it , but after 10 seconds, all surface disappear again.
Thanks!
Betreff: All surface on solid edge ST9 Disappears
Hi @Antech
can You provide a screen shot of the disapearing?
Are the surfaces not visible on screen or are the not longer shown in the pathfinder, ...?
Wolfgang
