Alternate Assemlbies
I am a former Solidworks and Inventor user and am new to Solidedge.  I have a gripper cylinder designed using alternate position, open and closed.  No issues there.  When I put the gripper assembly into my complete tooling assembly, how do I activate the gripper cylinder to show the open and closed conditions to design my tooling correctly
Re: Alternate Assemlbies
"replace"
When you use teh replace command you will be shown each config.
This "Multi level alternate position" scenario seems to be disabled in ST9... anyone encountered the same issue? Smiley Sad
