Alternate Position Assemblies in Top Assembly !!! (SE ST6 MP9)
Hi, included in attachment, you'll see at Top Level Assemly (1759-1-A00) that contains
Alternate Position Assemblies (1759-1-A01-OP1, and 1759-1-A01-OP2)
  When in the Assembly (1759-1-A01), I have no problem switching between
each of the alternate position that I created. Everything is just fine, no mismatch positions.
  But when I include the Alternate Position Assembly (1759-1-A01) in the Top Level Assembly
(1759-1-A00), there is some kind of garbage within the Assembly. Matrix pieces seems
out of place compared to the Alternate Position Assembly (1759-1-A01).
My Top Level Assembly (1759-1-A00), also has Alternate Position Assembly.
Take a look to my JPG, and you should be able to understand what I refering to.
If anyone has a solution for this, I'd appreciate. Did not have this kind of problem
with Solid Edge ST4 before.
Solid Edge ST6 Maintenance Pack installed 9.
thanks
