Angle, Deg-Min-Sec
Happy New Year,
I would like to display deg-min-sec on the doc. which shows on the angle window.
Any suggestions?
Once again
Happy New Year
Greg
Re: Angle, Deg-Min-Sec
Esteemed Contributor
Need to format your dimensions and change the units for angular to include it.
Production: ST9 MP7
Testing: ST10
If you are asking for the reset for the dimensions I have. I would like to
display on the document, not just on the ribbon. As the video shows the
dimensions is the standard not the deg-min-sec.
http://screencast.com/t/cwSOOjVi8
Thank You
Happy New Year
Greg
Hi Greg,   Because it's a full circle you're dimensioning...
Hi Greg,
Because it's a full circle you're dimensioning, it is expected to encompass 360 degrees, so the angular type of dimension is not available for selection.....if you were to draw a semi-circle [arc] you would get an option to apply an angular dimension and be able to display it that way.
Design Manager Streetscape Limited
Solid Edge ST10 [MP0] Classic [x2 seats]
Windows 10
