Re: Assembly 3D sketches problem
@Imics
You are an absolute genius - that worked perfectly.
I repeated the process for each sketch until all were OK.
Unfortunately I can only give you one kudo - deserves more.
What I find odd is that after closing the file while still in the sketch it re-opens back in assembly mode.
HP Z420 16GB RAM
Quadro K4000
@beachcomber I gave @Imicsa "Kudo" for you Smiley Happy
http://Grundey.blogspot.com
I gave @Imics a kudo as well. Jeesh! That's all we seem to do around here...give Imics kudos. Smiley Happy
It worked like a charm!. thanks
