Assembly 3D sketches problem
I have an assembly with several 3D sketches.
The last 3 in the pathfinder are showing an anti-clockwise blue arrow next to them and are not displaying.
In a part that would indicate the pathfinder has been rolled back to earlier features - by using "GoTo".
However there is no such command in assembly, so how does this happen.
I can edit the sketches but as soon as I close the sketch it disappears from view again.
I have added GoTo to my QAT but it has noe effect.
Any ideas ?
HP Z420 16GB RAM
Quadro K4000
13 REPLIES 13
Betreff: Assembly 3D sketches problem
Hi @beachcomber
fortunately I have read Your info about assembly!
As mentioned this is a typical "Go To" within a part.
OK, assembyl ?
Do You have a picture of the pathfinder.
Maybe this gives a hint how it was created, what the reason might be.
Wolfgang
Pathfinder image -
HP Z420 16GB RAM
Quadro K4000
If I add another 3D sketch it appears before the rolled-back sketches.
HP Z420 16GB RAM
Quadro K4000
Hi @beachcomber
You are using ST7, are You?
Wolfgang
Yes ST7 MP11
(must change my signature)
HP Z420 16GB RAM
Quadro K4000
Other than maybe trying to edit the sketch immediately preceding the rolled back ones and finishing it to see if it returns them to a good state, looks like a job for GTAC.
http://Grundey.blogspot.com
Tried everything on this - reported to VAR.
I can recreate the sketches fairly easily, but I like to know why and how this happened..
HP Z420 16GB RAM
Quadro K4000
Hi @beachcomber
... not only You!
Let us know what was going on when You get feedback from GTAC
Wolfgang
Re: Assembly 3D sketches problem
Hi @beachcomber,
Try this:
Open your assy and go into your rolled back 3D sketch. Save it and close Solid Edge here (don't go back from 3D sketch)! Start Solid Edge and look at your assy.
BR,
Imics
