Assembly Construction Default
https://youtu.be/HpQc1_17xbk4Himages (33).jpgdownload (1).jpgWith This Video Shows In Assembly Construction Default... All Parts Are A Color Purple, I've Tried The Unite Bodies. I Cannot Combine. I Would Like To Make One Piece. Any Suggestions.
Thank You
GregoryLee
Re: Assembly Construction Default
Greg,
You could try to use "Insert Part Copy" of the assembly file into a new [empty] Part environment model, then if the parts are in a condition to join, then use the Boolean tool group, selecting the "Unite" command.
Solid Edge ST10 [MP7] Classic [x2 seats]
