Assembly Drawing Background Image
I was wondering, does anyone know how to create a background image that is to scale with and assembly drawing.
Example., I created a workbench.  Now I want to display the work bench in the room that it will sit in.
Marcelo
Re: Assembly Drawing Background Image
you can use any image..   Scale will be based on your model's zoom level.
do some searching for "Keyshot" examples within the communiyt you will find more info there.
Matt Johnson
Teamcenter 10.1.6
Betreff: Assembly Drawing Background Image
Esteemed Contributor
Hi @floresma
besides the Keyshot solution - if You can use it - You also can define any picture as background for the Solid Edge window itself.
This also creates good first impressions, but nevertheless, a Keyshot rendering is better many times and much more realistic.
Wolfgang
Thanks for the help!
