Assembly Issues *Need Help*
I am having an issue with the relationship conflict error popping up when I attempt to add hardware to a component.  This is something that I do every day nearly and have never had an issue until today.  I have tested several components and different hardwares and even components to components and they will not mate to each other.  I'm sure this is something very simple to fix as I am by no means an expert at Solidedge.
Has anyone else had this issue before and how would I go about fixing this?
Re: Assembly Issues *Need Help*
There's not really enough info to say IMO but I have had this error inexplicably show up and an SE restart or soft reboot often clears it. In any case, that's the first thing to try.
Bruce Shand
I wound up just shutting it all down and rebooting.  The error cleared and I can once again rule the world!
Thank you,
