Assembly Previews Not Showing
We are running ST7 and are unable to see previews of .asm files in our file open dialog box. We can see previews of all other file types.
Anyone else see this? Am I missing a setting somewhere? I can open an assembly and go to "save preview now" and see it in the window as saved, but it will not display when the file is selected in the file open dialog box.
We have had this issue, as best I can recall, since we upgraded to ST7 when the open file dialog was changed.
TIA!
Bob Henry
Manager of Engineering - Highwall Miners
Caterpillar Global Mining LLC
Houston, PA
Re: Assembly Previews Not Showing
Hi Bob
I'm using ST8 but assuming 7 is similar: In the .asm template you are using, make sure the Store Preview check box is ticked in the Preview tab of the File Properties dialogue.
Application Menu>Properties>File Properties>Preview
Cheers
John
Unfortunately, the box is checked as it has always been and the previews still don't show.
I will call it in.
Bob Henry
Houston, PA
