Assembly - automaticaly show planes
I don't know if it exists, but I thought I read about it long time ago.
Is it possible when placing parts in an assembly to show the planes? Now I need to do some extra clicks and I thought I could show them when pressing a butting while clicking an the target part.
Somebody who can help?
Thanks!
Solid Edge ST10 & AutoCAD 2019 user
Re: Assembly - automaticaly show planes
Are 2 clicks ok for placing your parts in the Assembly? Or are you looking for another possibility?
Yasser
That's what I do now.
It is OK, but nothing is perfect.
I thought there was a shortcut to press while clicking on the target part that made these 2 clicks obsolete. Am I wrong?
Yes, you can do it from ST8.
SE Application button -> Options -> Assembly:
  • Show reference planes of component: (toggle on)
Keep display after placement or Hide after placement
BR,
Imics
I tried it with a shortcut of "Show Reference Plane". But we have to click on the Part first and we will still need 2 Clicks! Smiley Happy
Thanks, this is already half of the answer.
Now I need the same for the target part also. Man Tongue
Me difficult?
Noooo....
Joris, you remeber well but it works only with the FlashFit command.
- Select the FlashFit command
- Select the first face\plane
- Hold down R key
- Select the target part and the planes will be shown
- Release the R key
- Select the target face\plane
wish this "R" key method was available for other relations commands too.
Also wish there was a key to show construnction geometry that I use a lot as reference for 3D relations.
Thanks!
I don't like flash fit, so no luck for me.
@Joris wrote:
Thanks!
I don't like it either, time for a ER ?
@Joris wrote:
Thanks!
Just curious, what do you not like about FlashFit?
Greg
