Assembly drawing placing parts a fixed distanse on a specified axis.
I'm trying to space 2 posts 15 inches apart on my assembly drawing on the same axis.  Is there a quick any easy way to achieve this task?
Re: Assembly drawing placing parts a fixed distanse on a specified axis.
Hi there @floresma,
You could place the second instance of the post in the exact same loacation as the first one, then use the "Move on Select" command, select an axis on the steering wheel, typing in the distance to move.
Betreff: Assembly drawing placing parts a fixed distanse on a specified axis.
Hi @floresma
is Your question regarding to a "drawing" (draft) or - as answered by @SeanCresswell the positioning in an assembly
Wolfgang
