Assembly environment cannot work but the others working fine
I installed the standard parts libraries and the assmebly cannot open. It cannot open a new assembly either. But the others part, sheet metal, draft working fine.
Anyone know whats going on ?
7 REPLIES 7
Re: Assembly environment cannot work but the others working fine
Do you get any error message? Is there a .asm file in the templates folder?
Bruce Shand
WIN 10, st9
Capture.PNGWhen I was setting the standard part path, I mapped the sac. file in the setting (file location). And it poped out a window to suggest me to remember the view setting and I click NO. And after that, the assembly function is broken. It only shows a little commend bar on the up left coner.
It only shows this
Anything to do with the SQL server?
Is there a reason why you haven't asked your VAR or GTAC to help?
Bruce Shand
Betreff: Assembly environment cannot work but the others working fine
during the Standard Parts installation, do You have had installed the test standrad parts too?
As I remember, they wee necessary to install the SQL correctly.
And - as alway - have YOu turned off the UAC before starting the installation, and have You done it with "Run As Administrator"?
Wolfgang
