Assembly file updates
Is there an easy way, just using SE ST6, to prevent parts within an assembly file being updated automatically, for the parts within it to remain as they were when the file was last saved, and yet be prompted for the update/s to be carried out or not?
detectortester
Re: Assembly file updates
Siemens Genius Siemens Genius
Siemens Genius
We have tools in ST7 Assembly - Limited Update, Limited Save, Component Tracker - that would let you defer update of parts in an assembly. With ST6, you could use inactive parts so they don't update. Activating them will cause them to update the assembly.
Aditya
Aditya Gurushankar
Manager, Solid Edge Planning
