Assembly open
Sorry interrupting. JUst wanna to ask simple question. How to avoid missing File in assembly. Do I need to open few dozen parts modules in order to avoid this problem. Really need your solution. Thank you
Re: Assembly open
Need not explicitly open the parts. All that Solid Edge expects is the parts be located in the same folder location when the assembly was last saved. Right now, SE is not able to find them there.
You can pick the parts in the list and use one of the buttons on the right to specify a location where you think the parts might be found or simply specify a new part.
