Assembly
Hy guys,
I am looking for assembly Relationship Types - connections parts with different examples for each:
If you can put any good examples on youtube or where ever they are, or PDF book anything. I also work but some basic steps. I need some more, I am trying to put all this with different parts and shapes but it doesn;t work at all. I need your help. Thank you so much.
J.B. - Andreas
Re: Assembly
Re: Assembly
SE Help will give you everything you need in this regard.
https://docs.plm.automation.siemens.com/tdoc/se/109/se_help/#uid:xid453632
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
