Atomic Parts Report
Is there a way to indicate what sub-assemblies you don't want to be broken down to the patrs level when doing a Atomic Parts Report?
Thanks for the help
5 REPLIES 5
Betreff: Atomic Parts Report
Hi @lostriver319
are You talking about BOM in draft or as report from assembly?
Wolfgang
Report from an assembly
Hi @lostriver319
so the IMHO easiset way to achieve that is, to define those subassemblies, You do not want to be listet per part, as weldment model assembly.
A weldment, per definition, acts as a single part, in respect to the BOM.
If no other options or definitions will change it.
Wolfgang
Since a draft parts list is much more robust in this regard maybe it would be useful to use that then copy it to an Excel or text file.
Bruce Shand
I agree with, and my past experience has been... as suggest use drafting you can specify this control there.
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
