Attach Local Resources Error
Hello, I have a problem with the ST7 educational, license current, suddenly came to me this error
Error loading the LOCATE resources library, VWCMDS.drx
looks like it disappear some file, antivirus did not remove it, nor block,
anyone know how to fix it ??
Re: Attach Local Resources Error
Hi there,
You might try the method outlined by this site.....
http://www.highpcspeed.com/errors-exe/vwcmds.drx.html
A quick search and I see on my system that the file resides in "C:\Program Files\Solid Edge ST7\Program\ResDLLs\0009..." if that helps.
hi, its dont work, It seems that I will have to reinstall st7
