Auto Balloon in Draft
Does anyone know VB method that Auto Balloon of difference dimension after view updateing of draft document ?
8 REPLIES 8
Betreff: Auto Balloon in Draft
Hi @sho1313
Maybe better asking this question in the Developers Forum rather than there.
There the programming Guru's are posting, and You sooner will get better answers.
Wolfgang
Dear Wolfgang
Thank you for your reply!
@sho1313 Sounds like something the "Track Dimension Changes" command can do. Is that not adequate?
Bruce Shand
Hi @bshand
this could be usable in case of only tracking the changes.
But I can imagine that the ballooning of dimensions should become some kind of Quality Control list.
I remember those stamps in very old times to show and list all control dimensions.
Wolfgang
@hawcad To me the OP's question lacks clarity so I thought I'd ask.
Bruce Shand
Hi@bshand,hawcad,
 Thank you.
 In manually,'Update Views' makes Balloon of dimensions after updating.
 So, I do 'obj.ModelLink.UpdateViews' by VB. But, Balloon doesn't apper.
 Does it resolve by 'Track Dimension Changes' ?
 How use 'Track Dimension Changes command' ?
Hi @sho1313
So then the assumption by @bshand was absolutely correct, and You have talked about the Dimension Tracker.
This will mark all changed dimensions and is showing the type of changes.
How to invoke it from API is another issue?
But again You sooner will get an answer when asking this in the Developers Forum.
Wolfgang
Hi @hawcad
 Thanks for your answer.
 As you mensioned, I got an answer in the Developers Forum.
 I try it.
 Thank you so much.
