Auto cad scaling
Not applicable
when I inport a Autocad drawing the scal does not go with it IE on the original scale
it is 40 ft Solid edge showes as 3ft 3 in how can I correct this as i need to get
dimensions for Robot fencing and they are all off.
Second the help page does not come up it shows cannot start help?
Keep up the good work!!
Re: Auto cad scaling
Not applicable
James,
Can you add a post with a sample file and I will investigate your problem.
Rick B.
Re: Auto cad scaling here is the file
Not applicable
Not applicable
The file was not attached to the post.
Re: Auto cad scaling here is the filetrying again it was to large
Not applicable
>it said it was to large
Not applicable
Would you happen to be able to post the ACAD file?
"James S Baum" wrote in message
news:455a5150@bbsnotes.ugs.com...
Not applicable
James,
I need the original AutoCAD file. Email it directly to me.
ricky.black@ugs.com
Ricky Black
Solid Edge Product Manager - Draft / Data Migration
UGS - Transforming the process of innovation
256-705-2631
Not applicable
James,
You need to specify the units for the Draft file during translation. The
default units are inches. The original .DWG file is in feet. To Change the
units, start to open the file again. When you select the file in the file
open dialog, the Options button at the bottom of the dialog will be enabled.
Click the Options button. There may be a delay. There is a lot of
information in this file. Click the 'Next' button at the bottom of the
AutoCAD to Solid Edge translation Wizard dialog. Change the Units in the
Units combo box to feet. Click the 'Finish' button at the bottom right hand
of the dialog. You should get a message stating that you cannot overwrite
the original configuration file. Click OK. Click on Create new configuration
file. Click on the 'Copy to' button and save your configuration file
somewhere where you can remember it. Click Finish. You have created a custom
configuration for translation. When you get more familiar with the software
take another look at the translation options.
Rick B.
Not applicable
>James,
>Regards,
>Rick B.
Re: Auto cad scaling here is the filetrying again it was to large working
Not applicable
>James,
>Regards,
>Rick B.
>It worked!!
Thanks, the only problem left is the Help file does not work I get a can not start
help error when I try to use it?
Thanks again.
