Auto update model view?
I have an exploded drawing view which doesn't update it self when ever i change it in the model.
I have to go into properties > display > and then check for an update
is there a way to update automatically or can i set SE to let me know the view is out of date. as i have many sheets and views, so this can be time consuming. I've tried clicking the update view icon.
MagRiz
(ST9 User Est 01.18)
3 REPLIES 3
Re: Auto update model view?
Open the draft and make checked this option: Settings/Options/General/Assembly configuration changes make drawing views out-of-date in this draft file.
It is recommended to set this in your draft templates.
SE2019 MP3
@MagRiz
Well you need to respect those answering the correct answer by cliking on "Accept as Solution"
Smiley Happy
@Shiv_Madan
please be patient and allow time to review
MagRiz
