AutoCAD (DWG) Export failure in ST8
I have been exporting DWG and DXF files from Solid Edge draft files for years. ST 7 intorduced a few bugs but then an MP fixed them again. ST8 original and MP1 have major failures with exporting to AutoCAD formats. re-using old or even creating new drawings. I have had edge support staff in OZ look at the problem but we still do not have a solution. Has anyone found a work around for DWG export problems? Problems include drawing contents scattered all over the place. Some drawing views do not display all content. Text and dimensions are a mess. The list is huge.Any help appreciated. Regards Blakey.
Re: AutoCAD (DWG) Export failure in ST8
I have tried it multible times in ST8, save as DWG and open from DWG, and had no problems.
Perhaps the attached seacad.ini can help you?
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
