AutoCAD versions supported by Solid Edge ST9 and Solid Edge ST10
Hello averyone!
Were can I find information of the version of AutoCAD suported by Solid Edge?
Thank you!
Re: AutoCAD versions supported by Solid Edge ST9 and Solid Edge ST10
You can usually figure that out by looking at the Save As options for DWG.
ST10 supports up to the DWG 2013 format file.  The 2013 format version was used in AutoCAD 2013-2017.
AutoCAD 2018 introduced a new DWG format version (DWG 2018).  This verion is not supported yet in Solid Edge...
http://Grundey.blogspot.com
