Autoform software not recognizing flanges on our DXF files
We use Autoform software on our CNC brakepress and we are now getting an error that says" "Cannot locate any flanges from geometry, check for connection between line segments."  We were not having this problem prior to ST6.  Does anyone have a solution?Capture.JPG
Re: Autoform software not recognizing flanges on our DXF files
Are your DXF export settings the same? Did you carry them over from ST6 if they are custom? I'm assuming the Autoform software is looking for a specific line type or layer for the bend lines and is no longer finding it.
-Dylan Gondyke
I set them the same as we had been using since ST3.
