Automatic scrolling? Automatic pan?
My models and drafts won't stop scrolling up out of view. It's like it's set on automatic scroll or pan. Or it's stuck on scroll/pan. I've tried re-starting SE with no luck. Every file I open starts scrolling out of view and won't stop.
Any ideas?
5 REPLIES 5
Re: Automatic scrolling? Automatic pan?
Maybe your mouse wheel have troubles ? Did you try with another one ?
That's it, Spacenavigator 3D mouse acting up.
Thanks!
I've got an older 3D mouse and to many times had something sitting on it.  Now I have to recalibrate it every few days so it doesn't continuously scroll/zoom.
Brian Fritz
Solid Edge Certified Professional
Solid Edge 2019 latest MP
I presume there must be an optical sensor or something like that underaneath the 3DConnexion mouse 'knob' (for want of a better name) as occasionally when mine starts to wander on it's own (i.e. appears uncalibrated) if I blow out dust/dirt from the gap it immediately works perfectly again.
Great tip. Works fine now, thanks!
