Automatic updates ST7
Automatic updates don’t seem to be automatic.
I have an adjustable assembly of a clamp around a shaft, the shaft size is adjusted and the clamp should adjust its size to suit.
I have to click Update Active Level or Update All Open Documents for the assembly to update.
This updates fine in ST2
and Yes Automatic updates is on Smiley Happy
