BOM/Variable Table Remove Leading Zeros
Currently in a draft we drive the size of our blocks in our BOM from the variable table. When a part is less than 1" the numbers are listed as 0.75 or 0 3/4. It is not driven from the actual dimension so you can't just go to styles and turn leading zeros off. Is there another way to get rid of the leading zero?
