Re: Background Colour
Hello Wolfgang,
If you mean to change teplate settings here "C:\Program Files\Solid Edge ST10\Template\ISO Metric" then I have allready tried this as well. Nothing changed.
Hi @puhovsky
and wherefrom are You loading Your new documents?
From the same directory or from somewhere else?
Wolfgang
... sorry for that "silly" question.
But after changing the template it just is wokring as expected.
... normally!
Wolfgang
Dear Wolfgang,
I have made template changes in other template metric folder and everything works good.
Thank you for advice and wish you a good luck.
Brgs
Daniil
@puhovsky  schrieb:
Dear Wolfgang,
Brgs
Daniil
Hi @puhovsky
this means, problem is solved?
Wolfgang
